1998 Honda Civic Front Shock Install Fix
RRAMOS28
I have a 98 civic ex, and I need to replace the front driver side shock. Its a regular stock shock, and I have already taken off the damaged one. Not so easy to put in the new one...
Apr 16, 2006 at 7:32 AM
LOSONE
  • 1,616 POSTS
So true, just don't take off the plastic strap on a gas charged shock. I would jack up that side from the body on that side giving a little more room. With the tire removed you should be able to wiggle it in. Don't forget to use a jack stand for safety. Good luck
Apr 16, 2006 at 7:40 AM
Suggested Repair
Leave the plastic strap on a gas-charged shock. Jack that side from the body for more room, remove the tire, and wiggle the shock into place. Support the vehicle with a jack stand.
Conversation Summary
The owner of a 1998 Honda Civic EX has removed a damaged front driver-side stock shock and is having trouble installing the replacement. The expert advises leaving the plastic strap on a gas-charged shock, jacking the body for clearance, wiggling the shock in with the tire off, and using a jack stand.
