2001 Honda Civic Trunk Latch Cable Install Fix
CHOOK
How do I install the trunk latch cable?
May 22, 2007 at 12:19 PM
BRUCE HUNT
  • 3,754 POSTS
It would involve some definite opening of a number of areas. What happened? Did the cable break? Is the shielding still okay? I might consider leaving the shielding and sliding in a new piece of cable. Your big issue will be how to anchor at each end but that should be doable. Ripping out the old one is easy except for the carpet, the seat or anything that might have to be removed to gain access.
May 24, 2007 at 1:26 AM
Suggested Repair
If the cable sheath is intact, leave it in place and slide a new cable through it rather than ripping out the whole assembly. The main task is anchoring the cable securely at both ends. Access may require removing carpet, the seat, or other interior pieces.
Conversation Summary
The owner asked how to install the trunk latch cable on a 2001 Honda Civic. The expert said several interior areas must be opened and asked whether the cable broke and if the shielding is still okay. He suggested leaving the shielding and sliding in a new cable, noting that anchoring both ends is the main challenge and that carpet or the seat may need removal for access.
