2000 Honda Civic Flashing Check Engine Light Fix
BRODIE979
I have a 2000 Honda Civic si, 150,000 miles. Recently my check engine light came on after my cold air intake sucked up some water. The check engine light starting flashing this afternoon. My car was shaking during each gear and i had no power (hesitation/sluggish). If I put the car in neutral and pushed the gas, i had no problems. It seems like the entire engine is shaking at low rpms. What is going on and is this something very serious? Thanks for your time in advance.
Mar 8, 2007 at 11:52 AM
KIN CHAN
  • 453 POSTS
go to auto zone and get me the code ---> the diagnostic trouble code!!!...msg me whenu get those codes!!!!!
Mar 8, 2007 at 2:14 PM
BRODIE979
I recieved my codes. It was two pages worth of codes. I had a p0131, p0171, p0301, p0302, p0303, p0304, p0300, p1399, and p0170. I took my car to a mechanic and my spark plugs did not exsist. That was the case for all 4 cylinder misfires. I got a complete tune-up and that fixed that problem. My check engine light is still on and I think its a p0131. I haven't had a chance to take it back to Autozone yet. Anything to lose sleep over?
Mar 12, 2007 at 3:07 PM
BRUCE HUNT
  • 3,754 POSTS
Have the code pulled. If it is the bottom or lower O2 sensor, you don't need to drop everything and rush in to replace it. I would replace it as soon as I could. A bosch replacement sensor is a simple replacement job and it is reasonable in cost while easy to do yourself.
Mar 13, 2007 at 4:43 AM
Suggested Repair
The misfires were already fixed with a complete tune-up after the spark plugs were found missing. Have the remaining code read. If it is the lower oxygen sensor (P0131), replace it soon rather than as an emergency; a Bosch sensor is a reasonably priced, straightforward DIY replacement.
Conversation Summary
A 2000 Honda Civic Si developed a flashing check engine light, shaking, hesitation, and power loss after the cold air intake ingested water. Stored codes included P0131, P0171, P0170, P0300 through P0304, and P1399. A mechanic found the spark plugs missing on all four cylinders, and a tune-up fixed the misfires, but the light remained and was suspected to be P0131. The expert advised confirming the code and replacing the lower oxygen sensor soon, noting a Bosch sensor is an easy, reasonably priced DIY job.
