2001 Honda Civic Battery Light Flashing
BRADBAKES
i drive a 2001 honda civic si and am wondering when is a good time to change my timing belt. Also my battery light flashes when i turn on my car but when i drive and go over 3500 rpm it goes off. Can you please tell me these two things thank you.
Jun 5, 2007 at 2:42 PM
BRUCE HUNT
  • 3,754 POSTS
You didn't mention the miles on the vehicle. But Honda I believe recommends replacing the timing belt at 70K. In the end the call for when to do it is yours.
Battery light coming on is right now the more serious problem. It comes on to tell you it is having early problems. The higher rpm probably is able to satisfy the charging need but at lower speeds the charging is not working as efficiently as it should. I would get a reading on a volt meter to see what is being pushed to the battery at lower and upper rpm. You are probably looking at an alternator replacement.
Jun 6, 2007 at 1:20 AM
Suggested Repair
Measure charging voltage at low and high rpm. A battery light that clears above about 3500 rpm suggests weak charging and likely needs an alternator. The timing belt is typically due near 70,000 miles, but mileage was not given, so base that decision on mileage and condition.
Conversation Summary
The owner of a 2001 Honda Civic Si asked when to replace the timing belt and why the battery light flashes at startup then goes out above 3500 rpm. The expert said Honda's timing-belt interval is about 70,000 miles and the owner must decide based on mileage. The battery light is more urgent and likely indicates inefficient charging at lower rpm, so voltage should be checked and an alternator replacement is probable.
