Gas mileage not the same
PROZEE55
2001 Civic EX, 92,000 miles,Automatic Trans.
Gas mileage is not the same, engine makes a boooooging noise when cold and has a hesitation after I let off the gas and excelerate again. No CEL.
Also when I stop the rpm's will be at 1000 and a couple seconds later drop to 750 and stay. Can you suggest any fix?
Mar 16, 2006 at 8:15 AM
VANDRAGON
  • 298 POSTS
it could be the O2 sensor or just in need of an oil and air filter change.
Mar 19, 2006 at 2:21 AM
BRUCE HUNT
  • 3,754 POSTS
I would check the spark plug wires. They can cause some of the issues you mention.
Mar 20, 2006 at 6:07 AM
PROZEE55
Thanks for the reply
New oil & filter, new plugs,new air cleaner, cleaned throttle body, injector cleaner in the gas tank, still
eats gas.
Mar 21, 2006 at 9:05 AM
