2003 Honda Civic Exhaust Manifold Fit
NEKOCJ
I have a cracked exhaust manifold in a 2003 Honda Civic 4D, LX model with a manual transmission. Its hard to find decently priced exhaust manifolds for this type of car, however I found a nicely priced one for the exact car only this one is for an EX model. My question is can I place an exhaust manifold for a civic EX into my LX?
Thanks.
-CJ
May 30, 2006 at 7:35 AM
BRUCE HUNT
  • 3,754 POSTS
Right around the timing belt cover is an engine code. Something like F15B or such. If the exhaust is from the same engine type it should work. Junkyards have software that will match up the item you have and give you other years and models that will work.
May 30, 2006 at 2:49 PM
NEKOCJ
Thanks, but which one is the timing belt cover? And is this number on the cover or is it just next to it?
-CJ
May 30, 2006 at 6:39 PM
BRUCE HUNT
  • 3,754 POSTS
Timing belt cover is the plastic cover at the end of the engine. Usually on the driver side of the vehicle. It is where the alternator and A/C pump are. Often the cover is white and the number will be on a sticker.
May 31, 2006 at 1:11 AM
Suggested Repair
Confirm the engine code on the sticker on the timing belt cover, the plastic cover at the end of the engine, usually on the driver side near the alternator and A/C pump. An EX exhaust manifold should fit the LX only if it is for the same engine type. A junkyard can also cross-match compatible years and models.
Conversation Summary
The owner of a 2003 Honda Civic LX with a manual transmission has a cracked exhaust manifold and asks whether a Civic EX manifold will fit. The expert says it should work if it comes from the same engine type, identified by the engine code sticker on the timing belt cover, and notes that junkyards can match compatible parts.
