1997 Honda Civic White Smoke
CHANDARITH
I drive a 1997 Civic hatchback dx 5spd with 135,000. Every morning when I start my car a lot of white smoke comes out my exhaust, but stops when the car is warm up. But sometime when driving I gas on the pedal, I can still see some white smoke from the rear view mirror. Is this normal? or Is there any problems with my engine? How can I fixed this?
Oct 10, 2006 at 2:00 PM
BRUCE HUNT
  • 3,754 POSTS
Well white smoke especially in the morning could be nothing more than dew or condensation in the engine and exhaust. If the coolant level drops you will probably find it related to the white smoke. The head could be warped and then head gasket failing. Taking in the head and having it plained (sp) will do wonders. At the times that the white smoke is obvious and the car is warm, I would assume the engine is a little erratic in its running.
Oct 11, 2006 at 6:26 AM
Suggested Repair
Check the coolant level. Morning-only white smoke may be condensation, but if coolant is dropping, suspect a warped cylinder head and failing head gasket and have the head checked and planed. Warm smoke under acceleration may also mean the engine is running unevenly.
Conversation Summary
The owner of a 1997 Honda Civic reports heavy white exhaust smoke on cold morning starts that clears once the engine is warm, plus occasional smoke when accelerating. The expert says morning smoke may only be condensation, but a dropping coolant level points to a warped head and failing head gasket; planing the head may help, and smoke when warm may mean the engine is running unevenly.
