2001 Honda Civic Stalls at Stops
CHADSTERTX
I have a 2001 Honda Civic LX with 89,000 miles. I do not have a check engine light on but when I am sitting at a stop light, occasionally the engine abruptly shakes for a second like it is about to die but then recovers as if nothing happened. It hits randomly and so intensely that it is startling. I do not know where to begin to investigate this problem. Any suggestions?
Jan 11, 2007 at 9:09 PM
SERVICE WRITER
  • 9,123 POSTS
There is a technical sservice bullitin on a start clutch assy that fits the description, 5.0 hr job.
However there is also a software update regarding stalling at stops.
There are a few saftey recalls that you should make sure were done that are not related.
Jan 12, 2007 at 1:13 AM
Suggested Repair
Have a Honda dealer check the technical service bulletin for the start clutch assembly (about a 5-hour job) and the software update for stalling at stops. Also confirm that unrelated safety recalls were completed.
Conversation Summary
The owner of a 2001 Honda Civic LX with 89,000 miles reports an occasional abrupt engine shake at stop lights that feels like stalling, then recovers, with no check engine light. The expert says a start clutch assembly bulletin matches the symptom and notes a software update for stalling at stops, plus unrelated safety recalls to verify.
