1996 Honda Civic No Clutch Pressure
MFPICON
I HAVE A 96 CIVIC WITH 245,000 MILES, IT HAS A MANUAL TRANSMISSION.I JUST HAD A NEW CLUTCH INSTALLED 3 MONTHS AGO. I HAVE HAD NO PROBLEMS UNTIL THIS MORNING I COULD NOT SELECT ANY GEARS AND THERE IS NO PRESSURE IN MY CLUTCH PEDAL. ALSO THE ONLY GEAR I CAN GET IS REVERSE AND IT MAKES THIS LOUD GRINDING NOISE.PLEASE HELP!!DO I HAVE TO GET ANOTHER CLUTCH JOB?[/b]
Dec 2, 2006 at 5:23 AM
BRUCE HUNT
  • 3,754 POSTS
Check the clutch fluid in the resevoir. It will be the smaller of the two and see if it is low. Chances are either the master or slave unit has gone out. Look around the master where the resevoir is and see if you see any leaks. Check the slave which is on the outside of the tranny housing. Follow the lines from the master and see if any fluid is present from a line leak as well.
Dec 2, 2006 at 6:30 AM
Suggested Repair
Check the clutch fluid level in the smaller reservoir. Inspect the clutch master cylinder, slave cylinder on the transmission housing, and the hydraulic lines for leaks. A failed master or slave cylinder is more likely than another full clutch replacement.
Conversation Summary
The owner of a 1996 Honda Civic with a manual transmission reports no clutch pedal pressure and an inability to select gears except reverse, which grinds, three months after a new clutch was installed. The expert advises checking the clutch fluid and inspecting the master cylinder, slave cylinder, and lines for leaks, since one of those hydraulic components may have failed.
