Car Stalls
LAYAPOLE
I have a 1997 Honda Civic EX with 150,000 miles Manual transmission. when i got up this morning i started the car like always no problem but as i started driving for a mile the car begins to stall, but never shuts off. I would raise the rpm without having it in gear then it would drive for a little while then do the same can you tell me what the problem might be. Thanl you
Oct 8, 2007 at 3:33 AM
FISHERMAN
  • 937 POSTS
[quote:0617cb99ab="layapole"]I have a 1997 Honda Civic EX with 150,000 miles Manual transmission. when i got up this morning i started the car like always no problem but as i started driving for a mile the car begins to stall, but never shuts off. I would raise the rpm without having it in gear then it would drive for a little while then do the same can you tell me what the problem might be. Thanl you[/quote:0617cb99ab]
Hello!
The check engine light its on?
When was the last Tune-up?
any recent repairs?
Oct 8, 2007 at 3:40 AM
LAYAPOLE
[quote:fd0167fbf2="fisherman"][quote:fd0167fbf2="layapole"]I have a 1997 Honda Civic EX with 150,000 miles Manual transmission. when i got up this morning i started the car like always no problem but as i started driving for a mile the car begins to stall, but never shuts off. I would raise the rpm without having it in gear then it would drive for a little while then do the same can you tell me what the problem might be. Thanl you[/quote:fd0167fbf2]
Hello!
No the Check engine light is not on. I just recently changed the speed Sensor and the Cluster cause they both didnt work
any recent repairs?[/quote:fd0167fbf2]
Oct 8, 2007 at 3:44 AM
LAYAPOLE
The Check Engine Light is not on. The most recent repair was the changing of my Speed Sensor and the Cluster cause they didn't work
Oct 8, 2007 at 3:47 AM
FISHERMAN
  • 937 POSTS
[quote:f670f8cef0="layapole"]The Check Engine Light is not on. The most recent repair was the changing of my Speed Sensor and the Cluster cause they didn't work[/quote:f670f8cef0]
I think its time to do a tune-up..
Replace spark plugs, (NGK`s are good I do not recommend bosh Spark plugs)
distributor cap and rotor, wires, fuel filter and air filter,
also clean the EGR (if stuck open makes the engine to run rough)
We are going to start from here..
(the tune-up its not that expensive and your engine should run a lot better)
Oct 8, 2007 at 4:05 AM
