1994 Honda Civic AC Heat Intermittent
EWCLARY
'94 Honda Civic VX, 181,000 miles. Beginning a few months ago the AC/heat in my car would occasionally decide not to come on. After flipping the switch "on" no air would come out and the car would begin to idle higher than normal. Ironically, if I would go over a bump in the road the air would come back on (hot or cold, whichever the desired setting). Also, the lights on the face plate of the ac/heater switch flicker on and off. This leads me to think that the problem is electrical...loose wires or something??? I also tried to check the fuse, but could not find it in the fuse box located in the car or the one under the hood (I'm not too car savvy)! I realize it could also be the fan motor. Any help would be greatly appriciated!
May 29, 2007 at 9:37 AM
BRUCE HUNT
  • 3,754 POSTS
With the flickering of the light as you travel I would rule out the fan and this points to a short in the wiring in the dash. The increased rpm of the engine is the computer believing that the system is activated and is trying to compensate for the extra pull that it makes on the engine. It, however, does not know that the system did not kick in as it should. Find the loose connection.
May 30, 2007 at 3:25 AM
Suggested Repair
Inspect the climate-control wiring in the dash for a loose connection or short, and repair the faulty connection. The flickering switch lights make a failed blower motor less likely.
Conversation Summary
The owner of a 1994 Honda Civic reports that the AC and heat sometimes produce no airflow, the engine idles higher, and the control-panel lights flicker. Airflow sometimes returns after hitting a bump. The expert rules out the fan motor and attributes the symptoms to a loose connection or short in the dash wiring, with the higher idle caused by the computer compensating for an expected load.
