1995 Honda Civic Heater Line Leak
AYS
how the heater core connected to heater valve?
where is the heater line located?
Is there any way i can take out the heater core or valve to inspect a heater line tht leaks untifreeze undernet my dush board?
Oct 11, 2006 at 1:47 AM
BRUCE HUNT
  • 3,754 POSTS
They go in to the firewall from the back side of the engine. The line feeds from just on the left side of the intake manifold. I would find a repair manual from either the public library or buy on from the parts store. Best tool you can purchase.
Oct 11, 2006 at 6:29 AM
Suggested Repair
The heater lines enter the firewall from the rear of the engine, with the feed just left of the intake manifold. Consult a repair manual before removing the heater core or valve to inspect the line leaking antifreeze under the dash.
Conversation Summary
The owner of a 1995 Honda Civic Si asked how the heater core connects to the heater valve, where the heater line is located, and whether the core or valve can be removed to inspect a line leaking antifreeze under the dashboard. The expert said the lines enter the firewall from the back of the engine and feed from just left of the intake manifold, and recommended using a repair manual.
