1991 Honda Civic Oil Pressure Drop
HONDAMAN
I have a 91 civic with a 1.5 enigne with 257K on it. My problem is this. About a year ago I had problem with the oil light staying on after the engine was started but would go out in about 3-4 seconds. So I installed an oil guage after which I noted that the oil pressure was 70-75 psi when the car was started and settled out around 60 psi when warm, then the pressure would slowly drop off to about 20 psi. I replace the oil pump relief valve and spring from honda. Problem when away till a few days ago. Now the oil pressure is good when I first start the car but when you drive the pressure drops to 10-15 psi. The pressure slowly drops now when you rev the engine. I am really looking at getting a second opinion since it is a big job. Any advice would be helpful.
Feb 18, 2007 at 11:52 PM
  • 75,988 POSTS
[quote:eb9148992f="hondaman"]I have a 91 civic with a 1.5 enigne with 257K on it. My problem is this. About a year ago I had problem with the oil light staying on after the engine was started but would go out in about 3-4 seconds. So I installed an oil guage after which I noted that the oil pressure was 70-75 psi when the car was started and settled out around 60 psi when warm, then the pressure would slowly drop off to about 20 psi. I replace the oil pump relief valve and spring from honda. Problem when away till a few days ago. Now the oil pressure is good when I first start the car but when you drive the pressure drops to 10-15 psi. The pressure slowly drops now when you rev the engine. I am really looking at getting a second opinion since it is a big job. Any advice would be helpful.[/quote:eb9148992f]
You should have changed the pump-could be a clogged oil galleries or the bearings on the Cam/Rod/Main or the journals. Open it up and check the bearing clearance with the plastigage.
Feb 19, 2007 at 4:55 AM
Suggested Repair
Replace the oil pump and inspect for clogged oil galleries or worn cam, rod, or main bearings and journals. Open the engine and check bearing clearance with Plastigage.
Conversation Summary
The owner of a 1991 Honda Civic 1.5 with high mileage reports oil pressure that is good at startup but drops while driving, even after replacing the oil pump relief valve and spring. The expert says the oil pump should have been replaced and that clogged galleries or worn bearings or journals may be responsible, recommending the engine be opened and bearing clearance checked with Plastigage.
