1999 Honda Civic Low Oil and P0135
GVILLECR
I RECENTLY HAD MY CHECK ENGINE LIGHT COME ON AND PEP BOYS GAVE ME A CODE OF P0135 WHICH IS MORE THAN LIKELY AN O2 SENSOR. I'M THINKING I SHOULD REPLACE THE DOWNSTREAM SENSOR BUT 2 WEEKS AGO AT AROUND 5,000 MILES MY OIL LIGHT CAME ON AND I WAS 3 QUARTS LOW WHICH WAS ODD CAUSE I DONT HAVE A LEAK AND THE CAR ONLY HAS 70,000 ON IT. MY QUESTION IS DO YOU THINK IT COULD BE THAT I MIGHT HAVE A COMPRESSION PROBLEM AND SHOULD I CHANGE THE O2 SENSOR ANYWAYS?
THANKS
GVILLECR
Feb 2, 2007 at 1:39 PM
BRUCE HUNT
  • 3,754 POSTS
3 quarts low and you ask about compression. First of all a car is nice to drive but they do have to have someone watch out for them. The oil system is a 4 quart system and it was headed towards dry. YOU have to check the oil. You are positive that it doesn't have a leak. How can you be so confident and what even caused you to check the oil to find it low? How many miles on the oil change? Is there a fog behind you when you drive?
The O2 sensor can wait. It will not kill the car but the problem with the oil has to be rectified. It might even have pretty good compression. Nail down where the oil is going first.
Feb 2, 2007 at 2:43 PM
BRUCE HUNT
  • 3,754 POSTS
The plain truth is, it used to be a standard thing to check the oil at the gas station. You could even sit in your car and have the guy do it for free. But it got checked often. Today, we don't want to look like there could be something wrong with our car so we grab gas and drink and head down the road. After that we forget about the car and drive until it lets us know it some way that it is having problems. My comment is that you have missed checking it and the signs it was giving you.
Feb 3, 2007 at 2:54 AM
Suggested Repair
Address the severe oil loss before replacing the O2 sensor. Check the oil level often, confirm whether oil is leaking or being burned, and find where it is going. Code P0135 can wait; compression may still be acceptable once oil use is explained.
Conversation Summary
The owner of a 1999 Honda Civic DX had a check engine light with code P0135 and wondered whether to replace the downstream O2 sensor. The car was also about 3 quarts low on oil with no obvious leak. The expert said oil loss is the priority, the O2 sensor will not immediately damage the car, and compression may still be fine once the oil problem is identified.
