1999 Honda Civic 02 sensor
SWALUK
  • 1999 HONDA CIVIC
Engine Mechanical problem
1999 Honda Civic 4 cyl Front Wheel Drive Manual
i replaced the primary ok sensor as per the obd11 codes the problem still exists so I guess it is not the o2 sensor or could have I bought a faulty o2 sensor
Saturday, October 23rd, 2010 AT 7:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
What problem are you having? Is the check engine light on?
Saturday, October 23rd, 2010 AT 7:52 PM
SWALUK
  • 6 POSTS
EVAP Emission Control System Leak Detected (Control Canister System) error code 1457
Tuesday, October 26th, 2010 AT 10:56 PM
SWALUK
  • 6 POSTS
The check engine light is on
and gives error code 1457 it has been on 3 times in the past month every time I cancel it a few days go buy the car surges stuters then the light comes on then drives smooth again like it never happened
Tuesday, October 26th, 2010 AT 11:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure fuel fill cap is on tight and not cracked. There is a valve and soleniod that is on top of the fuel tank that sometimes become sticky on this model civic, if the fuel cap is good I would suggest replacing those.
Tuesday, October 26th, 2010 AT 11:14 PM
