2003 Honda Civic Headlights not working
2003 HONDA CIVIC
175,000 MILES • 4 CYL • 2WD • MANUAL
JBYERS86
When i start my car in the morning the DRL (daytime running light) is on which it should be until the e-brake is disengaged. Once i disengage the E-brake the light goes off, which it should. When i turn my headlights on, there is no low beam on either the left or the right side, but if I turn the high beams on they will work on both side. As it is only one bulb for the high and low beams would this indicate that there is a problem with the wiring harness? If so, what kind of expense and I looking at as far as a repair goes?
Jul 6, 2010 at 1:05 AM
KHLOW2008
  • 41,814 POSTS
Hi jbyers86,
Did you check the bulbs?
Other components that would affect the low headlights are :
1. Low beam cut relay .
2. light switch.
Jul 6, 2010 at 6:39 AM
JBYERS86
[quote:92c1d58524="KHLow2008"]Hi jbyers86,
2. light switch.[/quote:92c1d58524]
I did check the bulbs, i replaced them with new ones the other day and the low beams were still off but the high beams and the daytime running lights work fine.
Jul 6, 2010 at 6:46 AM
KHLOW2008
  • 41,814 POSTS
Check the low beam cut relay to see if it is working.
Jul 6, 2010 at 7:31 AM
