2002 Honda Civic slave cylinder and fork
2002 HONDA CIVIC
53,000 MILES • 4 CYL • FWD • MANUAL
CAMRSARO
im trying to bleed the slave cylinder and it wont build any pressure im asking to see if the fork should have any play. and normally does the rod on the slave push back or does it stay open cause mine does not push the fluid back to the master cylinder
May 2, 2009 at 5:02 PM
F4I_GUY
  • 3,302 POSTS
Vacuum will draw the slave cylinder back into its bore reach inturn will release pressure on the clutch fork.
It sounds like your clutch master cylinder is not producing any pressure.
May 3, 2009 at 2:39 AM
