2001 Honda Civic AC Not Cold
@000 vehilces do not use freon. The use R-134A Let me know.
I will let you know on what I find out once I take the car to his place.
Thanks.
Suggested Repair
Replace the A/C pressure switch (high or low, as identified). It is about $15 and screws off a nipple like a valve-stem cap with no refrigerant loss. Do not leave a ground jumper that keeps the compressor running continuously, which can ruin it. The system uses R-134A, not Freon.
Conversation Summary
A 2001 Honda Civic AC was not cold after a refrigerant charge. Grounding a pressure switch made the compressor run and produce cold air, but it stayed on regardless of the dash switch. The expert warned that constant compressor operation can ruin it, identified the part as an inexpensive screw-on pressure switch with no refrigerant loss, and said leaving the AC off for a week will not cause damage as long as the compressor is not running all the time. The owner disconnected the jumper and planned a dealer inspection.
