1993 Honda Civic A/C Stops Cooling
HONDAUSER
1993 Honda Civic LX Automatic Mileage 135000. My A/C cools off when I start the car in the morning. But when you get on the road for like a few minutes, it stops cooling off. You would have to turn the A/C switch off for like for a long time and then then turn back on, so it would cool off again.
What might be the cause of it? and approximately, how much does it cost to fix it?
thank you
May 28, 2006 at 11:17 PM
LOSONE
  • 1,616 POSTS
Do you have an R-12 or R-134A system.
If you are low on charge sometimes the system will freeze and it will have to thaw out before it will cool again. Check out your refigerant charge, it's probably low. losone
May 31, 2006 at 9:59 AM
Suggested Repair
Identify whether the A/C uses R-12 or R-134a and check the refrigerant charge. A low charge can freeze the system so it stops cooling until it thaws; correct a low charge if found.
Conversation Summary
The owner of a 1993 Honda Civic LX says the A/C cools after a morning start but stops after a few minutes of driving, then cools again only after the switch is left off for a long time. The expert asks whether the system is R-12 or R-134a and says a low refrigerant charge can freeze the system until it thaws. The recommended next step is to check the refrigerant charge.
