Battery has been charged and tested; starter has been tested and is working; fuel is being pumped through the filter and spark plugs are getting wet; spark plugs are firing when held against metal; pistons are pumping as felt through the plug openings.
Engine will turn over but no combustion. Tested injectors with multimeter and all test at over 10v, but cranking shows very little pulse on the multimeter and barely flashes a test light.
So, I've got fuel, spark and compression. What else can I test? I don't just want to buy a ECU or oxygen sensor, or PCM or ICM or Main Relay, or whatever without knowing it is the most likely cause
SPONSORED LINKS
Wednesday, October 21st, 2009 AT 2:40 PM
