1999 Honda Civic starting
MRMARK876
  • 1999 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 120,000 MILES
Problem started six months ago every once in while it would be hard to start 2-4 tries and while running occasannaly it would die (could hear a click and the entire insrament panel would shut down but it would start back up) now it has progressivly gotten worse to where it turns over but wont start. When you turn the key to the point where the instament panel should light up it dose not unless you jiggle the key or turn it to the point that it turns over, have replaced the battery and distributor mius cap and rotor
Saturday, October 24th, 2009 AT 4:09 PM
SERVICE WRITER
  • 9,123 POSTS
What you did is known is a wiggle test. By josteling wires you can flush out an intermitannt problem. Jigglng the key is a sign of a bad ignition switch.
I am assuming it will not crank?
I think you have 2 independent problems on this.
Take a quick look hear before you post back.
http://www.2carpros.com/kpages/first_things.htm
Saturday, October 24th, 2009 AT 4:22 PM
MRMARK876
It is a 1999 and it still cranks but wont start it will run if I hold the key on
Saturday, October 24th, 2009 AT 4:38 PM
SERVICE WRITER
  • 9,123 POSTS
Did you look at the link?
So you are saying this is a long crank condition?
That is it cranks but takes a long time to start.
IF this is the case, the key and wiggling have nothing to do with this. Just ironic.
Does this always happen?
That is will it do it when the engine has been warmed as well as when it sat overnight?
Saturday, October 24th, 2009 AT 5:04 PM
MRMARK876
I looked at the link.
It cranks but will not start. Warm or cold.
The instrement panel lights should come on when the ignition is turned to the next to last position, the postion before it starts to crank. This does not happen un less u jiggle it or turn it to the point it cranks.
Saturday, October 24th, 2009 AT 9:51 PM
SERVICE WRITER
  • 9,123 POSTS
Ok, Then I am back to the ignition switch. ID did a quick search of tsbs and found a saftey recall for the ignition switch.
Call the dealer with your VIN and see if it is open for you car.
02v120000 is the recall number.
Sunday, October 25th, 2009 AT 4:54 AM
