AC - no cold air
BECCA0WNZ
  • 1998 HONDA CIVIC
Noises problem
1998 Honda Civic 4 cyl Automatic 136000 miles
When my car is idle with the a/c on you hear a rhythmic screechy, mechanical type noise it seems to be near the accesorry belts which I had checked out and are fine. Also, every once or so often, from the moment I start the car, it blows warm air and I can be driving about 10 min and then the cool air will kick in. I went to a mechanic where he checked the compressor for leaks, he said it wasn't leaking but suggested I replace it although I strongly doubt its the compressor if not it wouldnt be cooling. Someone else told me it could be something with the pulley mechanism or a bearing. I dont know what to do! It get worse and worse as the weeks go by. :[
Saturday, June 20th, 2020 AT 11:01 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi becca0wnz,
If the crankshaft is incorporated with a damper, most probably it is faulty.
With engine started, does the pulley run out of lateral, (looks like it is waving )from top?
ANNGL
  • 5 POSTS
Ok, I have noticed the one on the driver side is not working at all. I have checked it. So it looks like it is the fan. Wow, I think I need to go have a dianostic check on it. The other comes on quite frequently. So it must be the fan. Thank you again for keeping in touch. And for your helpful advice.
BECCA0WNZ
Thank you for trying to help me out. How do I look for that? Because I can hear the noise but not see where its coming from.
KHLOW2008
  • 41,814 POSTS
You're welcome.
Yes, that seems to be the problem and to test the fan, you can disconnect it and apply battery voltage to the terminals. If fan works, the you would need to test the relays.
KHLOW2008
  • 41,814 POSTS
Hi becca0wnz,
From the belts look at the engine pulley, if it moves in a wavy pattern with the engine running, then it should be replaced.
ANNGL
  • 5 POSTS
Yes I will do that. Actually I did a little switching around with those under the hood and it does seem to get cooler from start now. It was taking time to cool then gets warmer as slowing down. But it does cool at on start now. Thank you for the advice. I will test that fan tomorrow. You've been very kind.I really do appreciate your help!
BECCA0WNZ
Is that expensive to replace or is it something I can do on my own with the civic manual? Will the part be available at any auto parts?
KHLOW2008
  • 41,814 POSTS
The main aim of our site is to help and we take it as our responsibility to assist as much as we can.
Keep me posted of any outcome.
KHLOW2008
  • 41,814 POSTS
Hi becca0wnz,
I don't know about the price and it would not be easy for you to replace it.
You need a special tool to hold it to remove the centre bolt which is torqued at 150 lbs.
Before doing anything, you need to confirm the part causing the noise. There is also the idler bearing and did you check the tension of the belt?
