1995 Honda Civic wont start
SOCCERCORY45
  • 1995 HONDA CIVIC
Engine Performance problem
1995 Honda Civic 4 cyl Front Wheel Drive Manual 133k miles
my car was running fine just a while ago and I was gonna change my spark plugs but decided not to leavin one wire disconnected from the plug accidently. I started it and it started but then bogged down and died. I tried to start it again and now it will not even try to start it cranks the starters working but the engine will not start. I tried eletric start. Push start. None of it even starts to get the engine going. What do youll think could be wrong. Did leaving the wire unplugged do something. And yes I did hook every thing back up perfect I only had one plug disconnected and its snapped back into place
Tuesday, April 28th, 2009 AT 10:51 PM
F4I_GUY
  • 3,302 POSTS
You most likely fried your ignition coil. Check the resistance of the coil and if it is out of spec, replace.
Wednesday, April 29th, 2009 AT 5:08 PM
ATKAPARKING
  • 64 POSTS
Yes, measuring resistance of the coil is a good step. Also, using a test light or voltmeter, check all your fuses. If these are good, are coil ohms out properly, these cars had lots of problems with the igniter unit inside the distributor. These can be tested as well, by which time you'll be well on the way to acquiring valuable Honda tech skills.
Thursday, April 30th, 2009 AT 12:03 PM
