Hi cdries123,
You should check if power is being supplied to the starter solenoid, if yes, the starter has failed.
If not, you need to check the circuit from the ignition to the starter. It could be a loose connection somewhere or a faulty igniton switch.
SPONSORED LINKS
Friday, October 17th, 2008 AT 12:27 PM
