1995 Honda Civic Starting problems
COSMOS20
  • 1995 HONDA CIVIC
  • 4 CYL
  • 133,000 MILES
For the past few days my car has been experiencing problems when I go to start the engine. It will start normal about a 3rd of the time and the rest of the time it will just keep cranking, until it finnally starts bogging real low and eventually turns over after I press the gas. I replaced the spark plugs, distributer cap, fuel filter, and oil filter hoping that would maybe cure the problem but none of which have worked. My check engine light has been on for a little over a month but I had encountered no problems until now. I am getting a spark, I have power. I'm thinking it is maybe the fuel pump, or the distributer but i'm not sure which one it may be. Due to the fact that both are expensive I do not wanna buy one, with it ending up being the other. I could use some assistance, and any help would do.
Thursday, August 27th, 2009 AT 3:21 PM
What you need to do is get the computer scanned for code/s there's a problem within the engine management system this is your starting point finding out what's wrong.
Thursday, August 27th, 2009 AT 9:11 PM
COSMOS20
Yeahh I looked in my manual, and online, but I can't seem to figure out if my car has the proper(newer) computer in it so that it can be checked. There doesn't seem to be a plug under the dash to plug it into a automotive computer
Friday, August 28th, 2009 AT 11:29 PM
Its behind right kick panel near the computer
Saturday, August 29th, 2009 AT 1:26 AM
COSMOS20
Thank you very much for the information. I will look for the connection, and reply my results.
Monday, August 31st, 2009 AT 5:12 PM
