Ok, more about my Honda. I have another question up which explains the problem I am having with my coolant system. My head gasket was done three times and on the third time the mechanic put stop leak in the system.
Ok, new part of story begins here:
After the mechanic put stop leak in the system I had changed the radiator, but even when backflushing the new radiator I noticed stop leak pellets coming out. My heater core is pretty clogged also. Here lies the main problem.
When using my car to make long trips it seems that an air pocket builds up in the coolant system around the fan sensor. The fan comes on late and the car runs hot until I bleed the system using the piss valve on top of the engine near the top radiator hose.
When the car has this blockage of air the upper and lower radiator hoses are mushy, even though the car is running hot and should have plenty of pressure. My radiator cap is good and working. After I bleed the system of air and the car cools down the coolant system pulls the coolant it needs in from the overflow tank.
When I restart the car I notice that the upper and lower radiator hoses are hard and not mushy and the car runs fine and my temp gauge doesn't go over 1/3 of the way up. When my car is running correctly the temp gauge never moves. It always stays at 1/3 of the way up.
Does this sound like another problem besides the head gasket going again?
SPONSORED LINKS
Monday, December 14th, 2020 AT 9:47 AM
(Merged)
