Air Conditioning Problem
KHLOW2008
  • 41,814 POSTS
Both problems should be related and caused by the control cables.
ADJUSTMENTS
AIR MIX CABLE
NOTE:
The purpose for adjusting the air mix cable is to ensure that the air
mix door is fully closed when the maximum cool position is selected.
1. At air mix door linkage (bottom of heater case), disengage air mix cable housing from clamp. Disconnect cable wire from air mix door control arm. At heater control panel, select maximum cool position and hold it in this position.
2. At air mix door linkage, hold door control arm in maximum cool position (hold it against stop). Reconnect cable wire to door control arm. Gently slide cable housing back to eliminate slack, then snap cable housing into clamp. Adjust heater valve cable. See HEATER (COOLANT) VALVE CABLE.
Note :
The purpose for adjusting the heater valve cable is to ensure that the heater valve is fully closed when the maximum cool position is selected.
1. At heater valve near engine compartment firewall, disengage cable housing from clamp and disconnect cable wire from heater valve. At control panel, set temperature control to maximum cool position and hold it in this position.
2. At air mix door linkage (bottom of heater case), hold door control arm in maximum cool position (hold it against stop). At engine compartment firewall, reconnect cable wire to heater valve. Gently slide cable housing back to eliminate slack, then snap cable housing into clamp.
Saturday, June 20th, 2020 AT 11:08 AM (Merged)
KANARI
  • 1994 HONDA CIVIC
Air Conditioning problem
1994 Honda Civic 4 cyl Two Wheel Drive Manual 200.00 miles
hi I have honda civic lx 1994 hase problamme with ac sometime work sometime not working
i know should be in relay 12 volt to sending to compressor is not 12 volt some time work sometime not not problamme from relay
F4I_GUY
  • 3,302 POSTS
Why do you suspect it's the relay?
Is your refrigerant topped up? Get an a/c diagnostic done first.
KANARI
No sometime work sometime not working when notworking no 12 volt when working everything fine
BRIAN68
  • HONDA CIVIC
'94 Honda Civic EX, 225,000 miles. Car recently started blowing warm air, even on cool mornings, with the vent from outside air, and the temp control all the way to the cool side. I'm thinking the "hot air" is not being shut off completely. What could be causing this, and how can I check it / fix it? I'm reasonably comfortable mechanically, and want to fix it myself if possible.
With summer almost on us, I don't want any hot/warm air coming into the car. We live in SC and already have had temps into the 90's.
Thanks for your help,
Brian.
BRUCE HUNT
  • 3,754 POSTS
Find or trace the cable from the temp control and inside the engine well is the valve to control the flow on the coolant line that feeds the heater for the car. The valve is not closing all the way. A system flush could rectify the problem but you may want to take off that valve and clean or replace it.
BRIAN68
Bruce,
I replaced the heater control valve last Friday, and it is now blowing nice and cold, with the temp on cold, and warm when temp control is moved to hot.
Thanks for your help!
Related Air Conditioner Not Working Content
