1993 Honda Civic wont start
ACURADRED
  • 1993 HONDA CIVIC
Engine Performance problem
1993 Honda Civic 4 cyl Two Wheel Drive Automatic
the engine turns but wont start?
Saturday, April 18th, 2009 AT 8:22 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, April 18th, 2009 AT 8:28 PM
ACURADRED
Thanks for the info trying it let you know outcome
Saturday, May 2nd, 2009 AT 8:47 AM
ACURADRED
Change the distributor now it start up thanks again for the help
Wednesday, January 20th, 2010 AT 11:21 PM
