1993 Honda Civic car will not run when its hot
DARTHMOAR19
  • 1993 HONDA CIVIC
Electrical problem
1993 Honda Civic 4 cyl Front Wheel Drive Manual
i have a 1.6 liter when the car is cold it will start but after it heats up it dies by itself I have changed the ignition module and coil and have changed the fuel pump relay when the car runs it runs smooth until it heats up then it dies and I try to restart and the engine just cranks over but will not start it cranks with alot of power so I dont think its the battery I have already put to much money into it I am running out of ideas the onlt thing I can think of now is the map senser of the ecm
Tuesday, December 22nd, 2009 AT 1:32 PM
Check the fuel pressure to rule out a failing fuel pump-
Tuesday, December 22nd, 2009 AT 1:36 PM
DARTHMOAR19
Sorry I forgot to mention that I already checked that
Tuesday, December 22nd, 2009 AT 1:41 PM
Hi Darthmoar19, Welcome to 2carpros and TY for the donation and selecting us as your auto repair site. Feel free to ask questions at anytime-Merry Christmas and a Happy New Year 2010
Check the fuel pressure if its within specs could be the fuel pump is failing
Tuesday, December 22nd, 2009 AT 1:42 PM
Are you getting ignition spark, also are the injectors pulsing
Tuesday, December 22nd, 2009 AT 1:47 PM
DARTHMOAR19
Also when iit shuts off I turn the key and the relay does not kick the pump on so I jumped the relay and the pump comes on but the car will still not start
DARTHMOAR19
I have changed the ignition coil and the module
Tuesday, December 22nd, 2009 AT 2:02 PM
