1993 Honda Civic Burning smell with a lil smoke
124,000 MILES • 4 CYL • 2WD • MANUAL
JENNUYNE
  • 6 POSTS
Less than a 2 weeks ago I had my oil pan gasket and valve covered gasket replaced because I had an oil leak and it was determned these parts were the problem. My car is STILL leaking oil and now it started smoking a very little bit (only seen when you open the hood) and there is a burning smell. What possibly could be the problem?
Jan 19, 2009 at 7:06 AM
BMRFIXIT
  • 19,053 POSTS
check oil pressure switch
recheck the gasket job that was done
Jan 19, 2009 at 10:13 AM
JENNUYNE
  • 6 POSTS
I will have the gasket job checked again but is it possible this guy messed up my engine or got water in it? He shouldnt have taken the whole engine apart, just the bottom, correct? But its leaking a mixture of oil and water, looks like chocolate milk..thats not good right? Is it possible water got in the engine or a head gasket has blown? I say head gasket because of the burning smell and smoke?
Jan 21, 2009 at 3:11 AM
BMRFIXIT
  • 19,053 POSTS
I would for sure have them recheck the work they did and let them tell you what they think
get another opinion
Jan 21, 2009 at 9:51 AM
JENNUYNE
  • 6 POSTS
Just to let you know, turns out they put a bad oil filter in the car with a hole in it...I appreciate you taking the time to respond to me though...thanks again.
Jan 22, 2009 at 1:40 AM
