1997 Honda Civic leaking oil
1997 HONDA CIVIC
137,782 MILES • 4 CYL • 2WD • AUTOMATIC
NNPT53
Hi!
Aftering driving from school to home, I noticed that leaking oil from the car down ground. Then, I went to the car repair, they told that I need to replace oil pan gasket. Was my car's oil pan gasket broken? And they redid my radio. It totally costed me 80$ for that. Please, show me what happened to my car.
Thanks.
Apr 9, 2008 at 8:20 PM
BRUCE HUNT
  • 3,754 POSTS
Too often people take their cars to a mechanic for repair and fail to look at the vehicle to atleast see if they can have an idea what is wrong. The idea here is not necessarily to have you fix the problem your self but rather to have you narrow down what it might be and prevent being taken advantage of.
I don't believe you were taken advantage of in this case but a quick examination under the car could have convinced you that the problem was an oil gasket leak. If this fixed the leak I think you did well.
The radio is something you did not give enough information on. But some garages pull the battery terminals off as a standard practice and in the case of Honda radios they would need to enter a code to get the radio working again.
Apr 10, 2008 at 2:22 PM
NNPT53
[quote:fa9faf4b10="Bruce Hunt"]Too often people take their cars to a mechanic for repair and fail to look at the vehicle to atleast see if they can have an idea what is wrong. The idea here is not necessarily to have you fix the problem your self but rather to have you narrow down what it might be and prevent being taken advantage of.
The radio is something you did not give enough information on. But some garages pull the battery terminals off as a standard practice and in the case of Honda radios they would need to enter a code to get the radio working again.[/quote:fa9faf4b10]
Apr 10, 2008 at 9:32 PM
