HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
SPONSORED LINKS
1988 Honda Civic
JERALC253
MEMBER
1988 HONDA CIVIC
Engine Performance problem
1988 Honda Civic
my car isnt turning on.
the distrubuter is makin a weird sound
could it be from the cold?
Monday, December 7th, 2009 AT 2:09 PM
KHLOW2008
MECHANIC
Hi jeralc253,
Remove the distributor cap and check the rotor shaft for excessive side play. Quite often the shaft bearing gives away and when this occurs, you would not be able to start as the distributor has failed.
SPONSORED LINKS
Thursday, December 10th, 2009 AT 1:42 AM
Please
login
or
register
to post a reply.
Related Engine Content
1995 Honda Civic Engine Idle
While Idling, The Engine Will Rev-up And Drop Back To The Normal Idle Speed Continuously.
Asked by
mwolfington
1 ANSWER
1995
HONDA CIVIC
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
Engine Coolant
I Am Wondering Why The Fluid Underneath My Radiator Cap Is Neon Green But The Fluid In The Engine Coolant Reservoir Is Blue?
Asked by
Sean92
2007
HONDA CIVIC
1993 Honda Civic Engine Cylinder Preasure
I Was Told The Engine Cylinder Preasure Was Supposed To Be In The Range Of 120psi And 150psi. The Engine Runs Great But The Cylinder...
Asked by
ronbus
1993
HONDA CIVIC
2000 Honda Civic My Car Makes Noises Suddenly
Hi I Have An Honda Civic Ex 2000. Some Days Ago, It Made Some Noises In The Back. I Don't Know What Going On There. I Was Driving And It...
Asked by
boytx21
1 IMAGE
2000
HONDA CIVIC
2003 Honda Civic Engine
Exhaust Mani. Become A Red Hot
Asked by
thanushathavabalan
2003
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Hybrid Engine
Hybrid Car
Fuel Economy
Online car repair manuals
