anyone know how hard it is to replace a water pump on a 94 accord? it's a 4 cylinder 4 door, not sure about lx...
Apr 4, 2006 at 3:52 AM
Treat the water pump as a timing-belt job and replace the belt at the same time. Use a repair manual, mark the pulleys before removal so timing stays aligned, and inspect the tensioner if coolant has dripped on it. Expect tight access and a stubborn crankshaft pulley bolt; a shop job was estimated around $600.
The owner asked how difficult it is to replace the water pump on a 1994 Honda Accord four-cylinder. Experts said it is a difficult, somewhat costly job because the pump is driven by the timing belt, which should also be replaced, and a wet tensioner may need replacement. DIY is possible with time, knowledge, tools, and a manual, but the pulleys must be marked and realigned exactly.
