Honda Accord P0420 Check Engine Light
CWALK7107
Car listed above is the EX; model, 2.3 liter engine with 115,000 miles. How can I isolate the issue? O2 sensor? Front or rear or both? Catalytic converter? Help please. CW
Jun 12, 2007 at 10:46 AM
KIN CHAN
  • 453 POSTS
i take it this is a O2 sensor code.. well, according what i learn in my Honda OBD2 class that's an air fuel ratio sensor not Oxygen sensor. only way to diagnose if it is a fault is using a Honda manufacture scanner. watch live data and mode 6. if it is a true Oxygen sensor code then it has to be the front. rear sensor is responsible for catalytic converter code.. anymore question? by the way a diagnostic code only means computer sense either sensor or components losing power/ground or the value is out of range as what computer expect. it didn't say the sensor is no good.
Jun 12, 2007 at 2:10 PM
Good afternoon,
You will need a scan tool that can read the voltage of the upstream and downstream O2 sensors.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
When the readings vary the same, that indicates the cat converter is bad. If the downstream sensor voltage stays stable, then it could be an exhaust leak in the system.
In most cases it is the cat converter, not the sensors. If they were bad, they would code separately for the sensors.
Mar 24, 2020 at 9:26 AM
Suggested Repair
Use a scan tool to compare upstream and downstream O2 sensor voltages. If both readings fluctuate the same way, the catalytic converter is likely bad. If the downstream voltage stays stable, check for an exhaust leak. Faulty sensors usually set their own codes.
Conversation Summary
A Honda Accord EX with a 2.3L engine and 115,000 miles has a check engine light and code P0420. One reply said diagnosis requires a Honda scanner and live data, and that a code does not prove a sensor is bad. The expert advised comparing upstream and downstream O2 voltages: matching variation points to a failed catalytic converter, while a stable downstream reading may indicate an exhaust leak. In most cases the converter, not the sensors, is the cause.
