1992 Honda Accord Code 43 Engine Skip
EPEREZ32
my 92 accord ex engine light comes on after 10 minutes of driving, the engine code i got is 43 ,I have been researching this code, it says left fuel supply system circut fault . what does this mean? I just got home now my engine is skipping.
Aug 6, 2007 at 7:40 AM
BRUCE HUNT
  • 3,754 POSTS
Replacing the O2 sensor should fix the problem. The skipping of the engine as you call it can be associated with the computer running on a default setting that is not correct but this allows it to skip the bad readings from the failing O2 sensor.
Aug 7, 2007 at 4:23 AM
Suggested Repair
Replace the oxygen sensor. The engine skipping can occur when the computer uses a default setting because of bad readings from a failing O2 sensor.
Conversation Summary
The owner of a 1992 Honda Accord EX reported the check engine light coming on after about 10 minutes of driving, with code 43 described as a left fuel supply system circuit fault, and the engine then skipping. The expert said replacing the O2 sensor should fix the problem and that the skipping can be associated with the computer running on an incorrect default setting to bypass bad readings from the failing sensor.
