Honda Accord Brake Lights and Shifter
NATALIE1
my honda runs great other then my break lights and gear shifter not working. I know it's not a fuse what else can it be and how much will it be to fix it.
Nov 1, 2007 at 7:47 AM
STACKOCAKES
Do you hear a click noise to see if your starter is trying to turn over the engine?
Aug 23, 2007 at 12:31 AM
BRUCE HUNT
  • 3,754 POSTS
I hope that you disconnected the battery when you replaced the alternator. Now I would check the connections for tightness and make sure they are clean as well. Battery good and fully charged?
Aug 29, 2007 at 9:39 AM
MERLIN2021
  • 17,250 POSTS
If you take a look at the brake pedal, and follow it up to the switch thats on the arm, see if it is missadjusted, or may need replacing, that switch turns the brake lights on and releases the shifter, it's the brake shift interlock. The part is about 20.00-30.00!
Nov 1, 2007 at 8:56 AM
Suggested Repair
Inspect the brake pedal switch (brake-shift interlock) for misadjustment and replace it if faulty. The switch controls the brake lights and shifter release; the part is about $20-30.
Conversation Summary
The owner of a Honda Accord says the brake lights and gear shifter do not work and that a fuse is not the cause. One reply asks about a starter click, and another suggests checking battery and alternator connections. An expert identifies the brake pedal switch, which turns on the brake lights and releases the shifter, and says it may be misadjusted or need replacement for about $20-30.
