1995 Honda Accord ABS and SRS Lights
STILL HUMMING
1995 Honda Accord EX, V-Tec 4 cylinder with 215,000 miles
Recently, the SRS light on the dash came on and can't figure out how to get to go out.
Last week, had new rotors and pads installed. Few days later, teenaged son driving and had to pull off road due to a bolt coming out of front caliber (according to mechanic). He fixed it but since then, ABS light comes on each time car is driven and stays on.
What is a/some possible cause(s)?
Apr 10, 2007 at 4:58 AM
BRUCE HUNT
  • 3,754 POSTS
On the ABS, there could be damage to the ABS sensor on that wheel's brake assembly. When the ABS comes on you can have a code pulled to assist with the problem. I would suggest you do that.
The SRS light. Check the fuses for that.
Apr 10, 2007 at 7:29 AM
Suggested Repair
Have the ABS codes pulled and inspect the ABS sensor on the affected front wheel for damage after the caliper bolt came loose. Also check the SRS fuses for the SRS light.
Conversation Summary
The owner of a 1995 Honda Accord says the SRS light stays on, and the ABS light stays on after a front caliper bolt came loose and was repaired following new rotors and pads. The expert suggests possible ABS sensor damage at that wheel, pulling ABS codes, and checking the SRS fuses.
