2000 Honda Accord Pulsating Steering
2000ACCORD
I have a 2000 honda accord 4 cyl 2.4L with 74000Km, I have noticed that when I break from over 50KPH that my steering vibrates or pulsates just a little until it goes down to 40KPH, it never does it if I break below 45 KPH.
I have no such problem while driving at any speed.
I checked the break fluid its ok. And the car does not make any noise while braking. Hope you can help me... I love my Honda.
Thank You
Jul 11, 2007 at 1:04 AM
MOPAR MAN
  • 8 POSTS
Sounds like you front brake rotors are warped " out of round" They will need to be taken off and turned and the front pads replaced. But have your mechanic check it and make sure that is the problem.
I hope I have help you in some way, if so please leave feed back.
Jul 31, 2007 at 2:41 PM
BRUCE HUNT
  • 3,754 POSTS
Please don't have the rotors turned. Not to knock your advice but from experience, they will again be pulsating. The rotors aren't that bad to buy new and they can stand the heat better than the thinner turned rotors. From experience, NEW in this case is the route.
Aug 1, 2007 at 1:01 AM
Suggested Repair
Have the front brakes inspected. Replace warped front rotors with new rotors rather than turning them, and replace the front pads as needed.
Conversation Summary
The owner of a 2000 Honda Accord reports slight steering pulsation when braking from above 50 km/h until speed drops to about 40 km/h, but not when braking from lower speeds. There is no noise and the brake fluid is fine. One reply suggested warped front rotors that should be turned and pads replaced. The expert advised against turning the rotors and recommended new rotors because turned rotors often pulsate again and handle heat less well.
