Overheating
MCASTPARK
  • HONDA ACCORD
My Honda Accord Lxi Fan will not turn on causing the car to overheat. Should I check the fuses or do I need to replace the swich for the radiator so the fan will turn on?
Sunday, March 19th, 2006 AT 12:27 AM
VANDRAGON
  • 298 POSTS
With the car not running, can you turn the fan freely by hand? It could be a relay or fuse! If you or anyone you know is good with wireing. Find the hot wire at the fan motor, dissconnect it and run a wire from the hot wire to the positive post on the battery and firmly touch the wire to it for a second. If the fan runs then I would vote for the temp sensor or fan relay.
Sunday, March 19th, 2006 AT 11:12 AM
