2001 Honda Accord Maintenance Light On Fix
JAY0923
I have Honda Accord 2001. I just got an oil & filter change and 1 day after that, the maintenance required sign stays on as soon as I turn on the engine of the car. I don't know why it is happening. Can someone help me with this? Thank you![/quote]
Dec 26, 2006 at 3:57 AM
BRUCE HUNT
  • 3,754 POSTS
Open up your owners manual. It tells you how to reset the light. It is easy to do and involves the key and the trip odometer reset button. This light is intended to come on every 10,000 miles or so to give you a heads up that maintenance is required. Reset it and it should be fine.
Dec 28, 2006 at 6:41 AM
Suggested Repair
Reset the maintenance required light using the owner's manual procedure, which uses the ignition key and the trip odometer reset button. The light is a scheduled reminder and should stay off after a proper reset.
Conversation Summary
The owner of a 2001 Honda Accord said the maintenance required light stayed on the day after an oil and filter change. The expert explained that the light is a reminder that comes on about every 10,000 miles and should be reset per the owner's manual using the key and trip odometer reset button.
