1992 Honda Accord Noise When Turning Right
MONK2413
I have a 1992 Honda Accord EX. Its got a 2.2L 4 Cylinder Engine and has about 250K miles. It has been through a flood once but from what i understand all of the main electronics were replaced. When i drive above 40 MPH the car will make a loud noise that sounds like its coming from the front passengers side tire. It only happens when i turn right. I have checked for wear but cannot find anything. Also when it is below around 50 degrees and i start up the car the RPM's tend to jump rapidly from about 1,000 to 1,500. I was told that this could be due to a vaccum leak.
Thanks,
Timothy Lassiter
Jul 2, 2007 at 10:12 AM
BRUCE HUNT
  • 3,754 POSTS
Check the cv boots on the car for cracks and tears. You might have a cv joint that is bad. Yours in this case could be very bad. Don't ignore it.
Check your engine coolant level and make sure it is full. When the system is warm slowly crack open a bleeder on the cooling system to let out air. Should be located on the top hose from the radiator near the head. Air in a system can cause the surging. Vac leaks can as well but they are usually a constant surge whether car is warm or cold.
Jul 3, 2007 at 12:51 AM
Suggested Repair
Inspect the CV boots for cracks or tears and replace a failing CV joint if needed; do not ignore the noise. Also confirm the coolant is full and bleed air from the cooling system, since trapped air can cause cold RPM surging.
Conversation Summary
The owner of a 1992 Honda Accord reports a loud noise from the front passenger side above 40 mph only when turning right, plus RPM surging on cold starts below about 50 degrees. The expert advises checking the CV boots and a possibly bad CV joint, and bleeding air from a full cooling system rather than assuming a vacuum leak.
