1987 Honda Accord Stalls When Turning
DRAGONFLY215
  • 5 POSTS
Everytime I turn the steering wheel past 3 o'clock to park or u-turn, the engine rpms drop suddenly and more often than not the engine cuts off. I have power steering fluid, so what is the problem?
Jan 19, 2007 at 2:09 PM
BRUCE HUNT
  • 3,754 POSTS
I understand your note about the power steering fluid and your assumption, but this should have nothing to do with the steering.
Help us out with a little bit more information. 1987 Honda Accord __ miles_______ Transmission_____
In order to fully answer these are quite helpful.
Jan 20, 2007 at 1:02 AM
DRAGONFLY215
  • 5 POSTS
Sorry I wasn't more clear. My car is an 87 Accord Lx, with 115,000 miles on it, auto transmission, and just received a major tune-up a month ago. The engine idle problem is quirky, when the car is cold it idle's extremely high, when I brake at a light, at the exact moment that my momentum is halted, the idle drops precariously, and whenever I turn the wheel too far it dies, and I can also feel resistance and sometimes a low humming sound, which made me think it had to do with the steering since it sounds like it is rubbing against something and the engine's idle cannot compensate for the extra resistance. Hopefully you can help me, I can't drive the car confidently for fear it will break down.
Jan 20, 2007 at 12:06 PM
BRUCE HUNT
  • 3,754 POSTS
Take off the belt on the power steering and turn the pump by hand. Is it difficult to turn or easy. Difficult the bearing is seizing, easy and it should be normal. Try all of the belt driven devices on the car.
Jan 21, 2007 at 8:06 AM
Suggested Repair
Remove the power steering belt and turn the pump by hand. If it is hard to turn, the pump bearing may be seizing. Check the other belt-driven accessories the same way.
Conversation Summary
The owner of a 1987 Honda Accord LX with 115,000 miles and an automatic transmission reported that the engine stalls when the steering wheel is turned past about 3 o'clock, with resistance and a humming sound. Idle is very high when cold and drops sharply when the car stops. The expert said this may not be a fluid issue and advised removing the power steering belt and turning the pump by hand, then checking the other belt-driven accessories the same way.
