1987 Honda Accord
60,000 MILES • 4 CYL • FWD • AUTOMATIC
KBURNS
it runs fine for about 5 min then the idle jumps from about 500 to 900 and it wants to die. i just replaced the coil and 2 injectors. i also just tuned it up
May 14, 2008 at 3:07 PM
  • 75,988 POSTS
Check the idle control solenoid valve and the boost solenoid to include the throttle angle sensor-
May 14, 2008 at 11:20 PM
KBURNS
[quote:11fe5a14d7="rasmataz"]Check the idle control solenoid valve and the boost solenoid to include the throttle angle sensor-[/quote:11fe5a14d7] where are the located?
May 15, 2008 at 5:16 AM
  • 75,988 POSTS
You need a repair manual for it-its just not finding it, there's certain procedures you have to follow to test it-and its in the book
May 15, 2008 at 8:32 AM
