1990 Honda Accord Spark Plug Change
CZY4HEELS
  • 7 POSTS
I need to change my spark plugs on my 1990 Honda Accord. I have never done this. Do you have a step by step guide to help me?
Thanks!
Dec 6, 2006 at 5:16 AM
BRUCE HUNT
  • 3,754 POSTS
You will need a socket for the spark plugs, one that will hold a plug to pull it out. You will need an extension to reach down in to the well that the plugs rest in and of course a rachet. Gently take one wire off and remove the plug. The new plug should be checked for gap and then carefully put in the engine to ensure that it does not get hit on the bottom that could cause the gap to close. Tighten it carefully to specs and replace the wire. Go on to the next ones. Keep them in line as you take them out so you know which came from which cylinder. I say this because the plugs are fanstastic indicators of the way the car is running.
I look at the plugs to see what is deposited on them, are they burnt, was the gap close to the original gap, etc. Another thing is to see if they look the same. Then you can determine whether the engine is consistant. If they look the same the cylinders will generally look the same inside, the compression will probably be close. A difference could indicate a weaker set of rings or an injector that is not performing correctly. You can find color pictures on the internet to indicate the problems indicated by plugs. Good luck!
Dec 6, 2006 at 7:32 AM
Suggested Repair
Change the spark plugs one at a time using a spark-plug socket, extension, and ratchet. Gap each new plug, lower it carefully into the well so the electrode is not damaged, tighten it to specification, and reconnect the wire. Keep the old plugs in cylinder order and compare their condition, deposits, burning, and gap.
Conversation Summary
The owner of a 1990 Honda Accord asked for a beginner step-by-step guide to changing the spark plugs. The expert recommended a plug socket, extension, and ratchet; removing one wire and plug at a time; checking the new plug gap; installing it carefully and tightening it to specification; then replacing the wire. The expert also advised keeping the old plugs in order and inspecting them for deposits, burning, gap wear, and differences that may indicate engine or injector issues.
