How do I replace the front right clearance light on a 1996 Honda Accord 2.2L 5-speed,(150000 K)?
Oct 25, 2007 at 8:23 AM
Under the hood, remove the screw holding the plastic arm to the clearance-light fixture, then slide the unit out. Watch the small plastic legs at the rear that fit into holes so they do not break.
The owner asked how to replace the front right clearance light on a 1996 Honda Accord 2.2L 5-speed with about 150,000 km. The expert said a screw under the hood usually holds a plastic arm to the fixture; removing it lets the unit slide out, and rear plastic legs that seat in holes should be handled carefully.
