1986 Honda Accord Overheating
HICKS253
Hi I have a 1986 honda accord dx manual transmission, My car is overheating all of the time , i have replaced the transmission, radiator, fuel filter, and did a tuneup all in the last 2 months, the engine is smoking alot under the hood, it will overheat and then die. I went to put water in it today and it spit it out, can someone please help me.
Aug 25, 2007 at 5:46 AM
STEVEONCHETCO
Try the thermostat, check your hoses, water pump
Sep 29, 2007 at 5:45 AM
BRUCE HUNT
  • 3,754 POSTS
You are having serious issues. I going to retell what I think you have said. Car overheats and uses or losses coolant. The engine smokes alot but under the hood. You put in a new radiator, not a used one right?
There are generally some smaller hoses that carry coolant and one of them could be leaking. The coolant must be hitting the exhaust system. Find the source of the leak and you might be ok. Are you sure it is not leaking at the radiator OR out the head?
The head could be warped. Heating the engine as you have mentioned does not mix well with a aluminum.
Oct 1, 2007 at 12:58 AM
Suggested Repair
Inspect the cooling system for leaks at the radiator, small coolant hoses, and cylinder head. Also check the thermostat and water pump. Repeated overheating may have warped the aluminum head, so confirm the leak source before further driving.
Conversation Summary
A 1986 Honda Accord DX with a manual transmission overheats, smokes under the hood, loses coolant, and then dies. Recent work included a transmission, radiator, fuel filter, and tune-up. Advice was to check the thermostat, hoses, and water pump, locate any coolant leak, and consider a warped cylinder head.
