1986 Honda Accord Overheating
TRAINMANDAN
hi 1986 honda accord, 157000 miles...the car overheats. I have found a leak in the top radiator hose. also the fans on the radiator do not come on...help?
May 20, 2006 at 12:52 PM
BRUCE HUNT
  • 3,754 POSTS
When you turn on the A/C do the fans come on? The hoses, yes hoses should be replaced. Check the engine and ground under it for moisture from a leak. I assume that the coolant level in the system will drop. If the system continues to overheat when the hoses are replaced, I would replace the thermostat.
May 23, 2006 at 5:55 AM
Suggested Repair
Replace the leaking top radiator hose and related hoses. Check whether the radiator fans come on when the A/C is turned on, and look under the engine for moisture from a coolant leak. If the engine still overheats after the hoses are replaced, replace the thermostat.
Conversation Summary
The owner of a 1986 Honda Accord with 157,000 miles reports overheating, a leak in the top radiator hose, and radiator fans that do not come on. The expert advises replacing the hoses, checking whether the fans run with the A/C on, inspecting under the engine for leak moisture, and replacing the thermostat if overheating continues after the hoses are replaced.
