1994 Honda Accord Headlights Not Working
NIRV78
I have a 1994 Honda Accord LX 4 door 73000 miles 4 Liter car. My problem has been that my front headlights are not working at all. I was told that it was a relay, but i'm not sure. If so, what type of relay do i need to purchase as in model brand and number. And where can i go online to purchase. Is it easy to install? Your help is much appreciated. Thanks.
Jul 31, 2007 at 3:43 AM
BRUCE HUNT
  • 3,754 POSTS
Under the hood there is a fuse box. It contains the relays as well. See if there is another one and swap to test.
Jul 31, 2007 at 9:52 AM
Suggested Repair
Open the under-hood fuse box, which also holds the relays, and swap the headlight relay with another identical relay to test whether the relay is the problem.
Conversation Summary
The owner of a 1994 Honda Accord reports that both front headlights do not work and was told a relay may be at fault. They asked which relay to buy, where to purchase it, and whether it is easy to install. The expert advised checking the under-hood fuse box and swapping relays to test.
