1988 Honda Accord Hard Start Rough Idle
FBJUNKIE53
Honda Accord
1988
208,000 miles
4 cyl. 2.0L FI
My car was getting really lousy mileage (about 20 mpg, usually 28 and up), stalled at idle, hard to start when the engine was warm, and had a foul smell of gasoline inside of the car. I found the injectors to be leaking, as I could see fuel residue around the injector ports on the manifold and around the ports on the fuel rail.
I replaced the injectors and the smell disappeared, but my mileage hasn't improved very much (around 23 now). It's still hard to start when the engine is warm and runs rough.
Did I miss something?
Jun 30, 2007 at 10:37 AM
BRUCE HUNT
  • 3,754 POSTS
I would probably look at the plugs as they may be fowled from too much fuel. Check the air cleaner. Look at the EGR valve and PCV.
Jul 2, 2007 at 1:14 AM
Suggested Repair
Inspect the spark plugs for fuel fouling, check the air cleaner, and inspect the EGR valve and PCV system.
Conversation Summary
The owner of a 1988 Honda Accord reported poor mileage, stalling at idle, hard warm starts, rough running, and a gasoline smell from leaking injectors. Replacing the injectors removed the smell, but mileage, warm starting, and rough running did not fully improve. The expert recommended checking for fouled spark plugs, the air cleaner, the EGR valve, and the PCV.
