Honda Accord P1382 CYP Sensor
MJB728
I have a 1996 Honda Accord that has almost 109,000 miles on it. The check engine light has come on and autozone ran a diagnostic for me. The error code os P1382, Cylinder Position Sensor No Signal. I was curious if this was an easy fix, a major problem and maybe even what it would cost to repair. Basically, what does this mean since the print out that they gave me said 1 an electical problem; 2 mechanical condition; or 3 failed CYP. Thanks.
Jul 12, 2007 at 5:51 AM
BRUCE HUNT
  • 3,754 POSTS
The CYP is located in the distributor. Chances are you would have to buy a whole new distributor. Junkyards might have one for you at a good price. Can be all three of those but I would suspect the Cylinder position sensor.
Oct 10, 2017 at 10:08 AM
JODELL8964
My 2002 Honda Accord has about 125,000 kms and has a 2.3L engine. It just recently came up with a CYP sensor error. My questions are: How critical is this error? Can I continue to drive the vehicle until I can get it into the garage? What are the risks of operating the vehicle until I can get it into the Garage?
Suggested Repair
The cylinder position (CYP) sensor is inside the distributor, so the usual fix is to replace the whole distributor. A used distributor from a junkyard may be a lower-cost option. The sensor itself is the most likely failure, though wiring or a mechanical issue is also possible.
Conversation Summary
The owner of a 1996 Honda Accord with about 109,000 miles reported code P1382, cylinder position sensor no signal, and asked whether it was an electrical problem, a mechanical condition, a failed CYP sensor, and what repair would cost. The expert said the CYP sensor is in the distributor, a complete distributor is usually required, a junkyard unit may be cheaper, and the sensor is the suspected failure. A later owner of a 2002 Accord asked how critical a CYP error is and whether the car can be driven until repaired, but that question was not answered.
